Model.midsurfaceextract#
Model.midsurfaceextract(collection, mode, thickness_bound, min_thickness, max_thickness, reserved_2, reserved_3, new_or_curr_comp)#
Extracts a midsurface from a pair of two surfaces.
Previously, this function was also used to extract a midsurface from a solid or from multiple surfaces. The function will still work in that manner for backwards compatibility but the function Model.midsurface_extract_10() is now recommended for those situations. The options listed below are the currently recommended options.
Parameters:
  • collection (Collection) – The collection containing the entities.
  • mode (int) –
    1 - Surface pair without “combine with adjacent plates” and “combine all adjacent plates” options.
    2 - Surface pair with “combine with adjacent plates” and without “combine all adjacent plates” options.
    3 - Surface pair with “combine with adjacent plates” and “combine all adjacent plates” options.
  • thickness_bound (int) – Not required for surface pair extraction. Value = 0.
  • min_thickness (double) – Not required for surface pair extraction. Value = 0.
  • max_thickness (double) – Not required for surface pair extraction. Value = 0.
  • reserved_2 (Collection) – Reserved for future development. Set it as empty collection.
  • reserved_3 (int) – Reserved for future development. Value = 0.
  • new_or_curr_comp (int) –
    0 - Midsurface will be created in the current component.
    1 - Midsurface will be created in a new component named middle surface.
Example#
Extract the midsurface between surfaces 10 and 15 use the “ combine with adjacent plates “ and “ combine all adjacent plates “ options and organize them into the “ middle surface “ component#
import hm
import hm.entities as ent
model = hm.Model()
surface_collection = hm.Collection(model, ent.Surface, [10, 15])
model.midsurfaceextract(
    collection=surface_collection,
    mode=3,
    thickness_bound=0,
    min_thickness=0,
    max_thickness=0,
    reserved_2=hm.Collection(model, ent.Component, populate=False),
    reserved_3=0,
    new_or_curr_comp=1,
