Model.modelcheck_applycorrection#
Model.modelcheck_applycorrection(check_display_name, correction_display_name)#
Runs auto correction on a given check, if checks are run.
Parameters:
  • check_display_name (hwString) – The GUI display name of the check. This is case sensitive.
  • correction_display_name (hwString) –
    The GUI name of the correction. This is case sensitive.
    If not provided, the then default auto correction associated with the check is applied.
Example#
Run the “Delete unused materials” auto correction for “Unused materials”#
import hm
import hm.entities as ent
model = hm.Model()
model.modelcheck_applycorrection(
    check_display_name="Unused materials",
    correction_display_name="Delete unused materials",
