Model.hmmeshsurfaceplane#
- Model.hmmeshsurfaceplane(quads)#
Within the automeshing module, generates quad or tria elements using a surfaceless algorithm. Can only be used with
model.surfacemode(mode=3)andModel.surfaceplane()function.- Parameters:
quads (int) – If nonzero, specifies that the created elements should be quads.
Example#
Create a square , planar surface normal to the x axis with the center at the origin , of size 10.0 , and create 45 elements#import hm import hm.entities as ent model = hm.Model() model.surfacemode(mode=3) model.surfaceplane(plane_normal=[1.0,0.0,0.0],plane_base=[0.0,0.0,0.0],size=10.0) model.set_meshedgeparams( edge_index=0, elem_density=5.0, alg_type=0, bias_style=0, bias=0.0, min_size=0.0, max_size=0.0, chordal_dev=0.0, max_angle=0.0, ) model.set_meshedgeparams( edge_index=1, elem_density=9.0, alg_type=0, bias_style=0, bias=0.0, min_size=0.0, max_size=0.0, chordal_dev=0.0, max_angle=0.0, ) model.set_meshedgeparams( edge_index=2, elem_density=5.0, alg_type=0, bias_style=0, bias=0.0, min_size=0.0, max_size=0.0, chordal_dev=0.0, max_angle=0.0, ) model.set_meshedgeparams( edge_index=3, elem_density=9.0, alg_type=0, bias_style=0, bias=0.0, min_size=0.0, max_size=0.0, chordal_dev=0.0, max_angle=0.0, ) model.hmmeshsurfaceplane(quads=1) model.storemeshtodatabase(elemstosurfcomp=0) model.ameshclearsurface()
