Model.hm_comparegettransformationmatchcount#
- Model.hm_comparegettransformationmatchcount(transformation_index)#
Returns the number of matches for a specific transformation. This must be preceded by a call to a relevant hm_compareentities function.
- Parameters:
transformation_index (int) – The index of the transformation to query, starting with 0. The number of transformations can be found using
Model.hm_comparegettransformationcount().- Returns:
hwReturnStatus- Status objectHmQueryResult- Result object containing the output values:numberOfMatches (int)
Example#
Find the number of matches for transformation 0 for the recursive comparison of surfaces with IDs 1 - 20 and 101 - 120#import hm import hm.entities as ent model = hm.Model() surf1 = hm.Collection(model, ent.Surface, list(range(1, 21))) surf2 = hm.Collection(model, ent.Surface, list(range(101, 121))) model.hm_compareinit() model.hm_compareentitiesrecursive( source_surfaces=surf1, target_surfaces=surf2, tolerance=0.1, result_type=2, review_results=False, ) _, result = model.hm_comparegettransformationmatchcount(transformation_index=0) num_matches = result.numberOfMatches print("num_matches", num_matches) model.hm_compareend()
