Model.featurelinesdetection#
- Model.featurelinesdetection(markmask, edgeFeatAngle, minCurv, maxCurv)#
Performs feature line detection using the curvature-based method. This method analyzes surface curvature and edge angles to generate topology lines from a mesh.
- Parameters:
markmask (Collection) – The collection containing the input element or component entities.
edgeFeatAngle (int) – The edge feature angle. Valid value range is 1-180. If set to 180, angle-based feature detection is disabled.
minCurv (int) – The minimum curvature filter.
maxCurv (int) – The maximum curvature filter.
Example#
Generate features on displayed elements using edge feature angle of 30.0 degrees#import hm import hm.entities as ent model = hm.Model() displayed_elems = hm.CollectionByDisplayed(model,ent.Element) model.featurelinesdetection( markmask=displayed_elems, edgeFeatAngle=30, minCurv=0, maxCurv=0 )
