Model.hm_ce_globalget#
- Model.hm_ce_globalget(global_type, global_name)#
Returns the value of a global connector variable.
- Parameters:
global_type (hwString) – double or int
global_name (hwString) – Valid values are g_ce_colorby, g_ce_imprint_remesh_rebuild_layers, g_ce_realizedvis, g_ce_unrealizedvis, g_ce_failedvis, g_ce_lt2tvis, g_ce_2tvis, g_ce_3tvis, g_ce_gt3tvis, g_ce_spotvis, g_ce_seamvis, g_ce_areavis, g_ce_boltvis, g_ce_applymassvis, g_ce_size.
- Returns:
hwReturnStatus- Status objectHmQueryResult- Result object containing the output values:Keys valid for
global_type="double"variableValue (double)
Keys valid for
global_type="int"variableValue (int)
Example#
Get all global variables#import hm import hm.entities as ent model = hm.Model() _, result = model.hm_ce_globalget( global_type="int", global_name="g_ce_failedvis" ) print("Variable's Value: ", result.variableValue)
