Model.morphtranslateshapemark#
- Model.morphtranslateshapemark(s_collection, n_collection, a_collection, base_node_entity, mode, tol, con)#
Translates each shape on the
s_collectionby a vector measured from the basenode to each node onn_collectionand affect only the nodes ona_collection. The shapes may be applied to the mesh, created as new shapes, added to existing shapes, or may replace existing shapes.- Parameters:
s_collection (Collection) – The collection containing the shape entities to translate.
n_collection (Collection) – The collection containing the node entities that are to translate to final position nodes.
a_collection (Collection) – The collection containing the target node entities.
base_node_entity (Entity) – The object describing the entity.
mode (int) –
0 - Apply each shape to the mesh.
1 - Apply each shape and add the perturbations to the original shape.
2 - Apply each shape and overwrite the original shape.
3 - Apply each shape and create a new shape or shapes.
4 - Create a new shape or shapes but do not apply them to the mesh.
tol (double) – The “envelope” or distance around the translated shape inside which nodes are affected.
con (int) –
0 - Do not use constraints.
1 - Use constraints.
Examples#
Translate a shape from one node to another and apply it to the mesh#import hm import hm.entities as ent model = hm.Model() model.morphtranslateshapemark( s_collection=(hm.Collection(model, ent.Shape, 1)), n_collection=hm.Collection(model, ent.Node, 12), a_collection=hm.Collection(model, ent.Node), base_node_entity=ent.Node(model, 11), mode=0, tol=3.0, con=1, )
Translate all shapes from one node to another and create new shapes, but only on selected nodes#import hm import hm.entities as ent model = hm.Model() model.morphtranslateshapemark( s_collection=(hm.Collection(model, ent.Shape)), n_collection=hm.Collection(model, ent.Node, 12), a_collection=hm.Collection( model, ent.Node, [1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12] ), base_node_entity=ent.Node(model, 11), mode=4, tol=3.0, con=1, )
