Model.create_lines_by_mesh_plane_intersection#
Model.create_lines_by_mesh_plane_intersection(collection, edge_break_angle, x0, y0, z0, x1, y1, z1, x2, y2, z2, x3, y3, z3)#
Creates lines at the intersection between input elements and the plane and further breaks them into different segments based on the input edge_break_angle. The plane is assumed to be quadrilateral, bounded between four points that are input in cyclic order to the function. The lines at the intersections are created in a new component “mesh_plane_intersection_lines.”
Parameters:
  • collection (Collection) – The collection containing the input element entities.
  • edge_break_angle (double) – The line break angle in degrees.
  • x0 (double) – The x-coordinate of the 0th point.
  • y0 (double) – The y-coordinate of the 0th point.
  • z0 (double) – The z-coordinate of the 0th point.
  • x1 (double) – The x-coordinate of the 1st point.
  • y1 (double) – The y-coordinate of the 1st point.
  • z1 (double) – The z-coordinate of the 1st point.
  • x2 (double) – The x-coordinate of the 2nd point.
  • y2 (double) – The y-coordinate of the 2nd point.
  • z2 (double) – The z-coordinate of the 2nd point.
  • x3 (double) – The x-coordinate of the 3rd point.
  • y3 (double) – The y-coordinate of the 3rd point.
  • z3 (double) – The z-coordinate of the 3rd point.
Example#
Create lines at the intersection of any displayed elements and a plane defined by points with IDs 30 , 27 , 22 , 35 ( in cyclic order ) and break them if the angle is greater than 20 degrees#
import hm
import hm.entities as ent
model = hm.Model()
# We need the point coordinates from the points with IDs 30, 27, 22, 35
p30 = ent.Point(model, 30)
p27 = ent.Point(model, 27)
p22 = ent.Point(model, 22)
p35 = ent.Point(model, 35)
x30, y30, z30 = p30.coordinates
x27, y27, z27 = p27.coordinates
x22, y22, z22 = p22.coordinates
x35, y35, z35 = p35.coordinates
# Creating the lines at the intersection of any displayed elements
elememt_collection = hm.CollectionByDisplayed(model, ent.Element)
model.create_lines_by_mesh_plane_intersection(
    collection=elememt_collection,
    edge_break_angle=20.0,
    x0=x30,
    y0=y30,
    z0=z30,
    x1=x27,
    y1=y27,
    z1=z27,
    x2=x22,
    y2=y22,
    z2=z22,
    x3=x35,
    y3=y35,
    z3=z35,
