Model.hm_holedetectionend#
Model.hm_holedetectionend()#
Clears memory and ends the hole detection module. This must be preceded by any calls to Model.hm_holedetectioninit() and other hm_holedetection APIs.
“Major” database changes made while inside of the hole detection module will invalidate and delete any results.
Returns:
Example#
Detect holes of any shape in all surfaces in the model and write the hole details shape_type, center, radius, and entities_list to a text file.#
import hm
import hm.entities as ent
model = hm.Model()
with open("C:/temp/holes.txt", "w") as holesfile:
    surf_collection = hm.Collection(model, ent.Surface)
    model.hm_holedetectioninit()
    model.hm_holedetectionsetentities(collection=surf_collection)
    model.hm_holedetectionsetholeparams(hole_shape=31)
    model.hm_holedetectionfindholes(find=1)  # For holes we need to set find=1
    _, result = model.hm_holedetectiongetnumberofholes()
    num_holes = result.numberOfHoles
    if num_holes > 0:
        holesfile.write(f"Number of holes = {num_holes}\n\n")
        for n in range(num_holes):
            holesfile.write(f"Queried data details of hole {n+1}\n")
            _, result = model.hm_holedetectiongetholedetailsdata(
                index=n, query_key="shape_type"
            holesfile.write(f"shape-type = {result.queryValue}\n")
                index=n, query_key="center"
            holesfile.write(f"center = {result.queryValue}\n")
                index=n, query_key="radius"
            holesfile.write(f"radius = {result.queryValue}\n")
                index=n, query_key="entities_list"
            holesfile.write(f"entities_list = {result.queryValue}\n\n")
    else:
        holesfile.write("Holes not detected.\n")
    model.hm_holedetectionend()
    holesfile.close()
