Model.blocknodeupdate#
Model.blocknodeupdate(name, function, type, start, end, number, factor)#
Updates the finite difference nodes in a finite difference block.
Parameters:
  • name (hwString) – The name of the block.
  • function (int) –
    0 - add nodes to an index.
    1 - remove nodes from an index.
    2 - remove all nodes from an index.
  • type (int) –
    The index. Not used, if function is 2.
    0 - i
    1 - j
    2 - k
  • start (double) – The starting position of the nodes to be added or removed. Not used, if function is 2.
  • end (double) – The ending position of the nodes to be added or removed. Not used, if function is 2.
  • number (int) – The number of nodes to add. Not used, if function is 1 or 2.
  • factor (double) – The expansion factor. Not used, if function is 1 or 2.
Example#
Add 50 nodes uniformly in the k direction to an existing block named block1#
import hm
model = hm.Model()
model.blocknodeupdate(
    name="block1", function=0, type=2, start=-10.0, end=110.0, number=50, factor=1.0
