Model.CE_ConvertByMark#
- Model.CE_ConvertByMark(collection, source_style, target_style, reserved1, reserved2)#
Converts between bolt and spot connectors.
- Parameters:
collection (Collection) – The collection containing the connector entities to convert.
source_style (hwString) – The source connector style. Valid values are “spot” and “bolt”.
target_style (hwString) – The target connector style. Valid values are “spot” and “bolt.”
reserved1 (int) – Reserved for future use. Must be set to 0.
reserved2 (int) – Reserved for future use. Must be set to 0.
Example#
Convert spot connectors with IDs 101 and 102 to bolt connectors#import hm import hm.entities as ent model = hm.Model() model.CE_ConvertByMark( collection=hm.Collection(model, ent.Connector, [101, 102]), source_style="spot", target_style="bolt", reserved1=0, reserved2=0, )
