Model.createsinglewallbulkhead#
Model.createsinglewallbulkhead(elementsCollection, domElementsCollection, normal, plane_point, flange_width, mesh_elem_size, thickness, offset, realizeconnectors=True, material=Entity(), connectorControl=Entity())#
Creates single wall bulkhead at the C section formed by selected elements with given width of flanges and sets the thickness property card with given thickness.
Parameters:
  • elementsCollection (Collection) – The collection containing the element entities of the C section.
  • domElementsCollection (Collection) – The collection containing the element entities from the dominant face of C section
  • normal (hwTriple) – The normal direction defining the main bulkhead plane.
  • plane_point (hwTriple) – The coordinates of the base point defining the position of the bulkhead.
  • flange_width (double) – The width of the bulkhead flanges.
  • mesh_elem_size (double) – The element size used for the bulkhead mesh.
  • thickness (double) – The thickness value assigned to the property card of the bulkhead.
  • offset (double) – The extra offset value for the bulkhead flanges. The default offset value is calculated from the C section thickness and the specified bulkhead thickness.
  • realizeconnectors (bool) –
    The flag enabling connector realizations.
    False - Connectors are not realized.
    True - Connectors are realized.
  • material (Entity) – The object describing the material entity which will be set as the material property for the created bulkhead. This is an optional argument.
  • connectorControl (Entity) – The object describing the connectorcontrol entity used to realize the connectors.
Example#
Create a single wall bulkhead in a C section defined by elements with IDs 1 - 9889 , with elements with IDs 8396 and 8418 from the dominant face , with the base point at x= 42.6 , y = -21.9 , z = 223.9 , the normal vector ( 0 , 0 , -1 ) , the width of flanges 32.0 , element size of 3.0 , thickness of 2.0 and with no extra offset#
import hm
import hm.entities as ent
model = hm.Model()
model.createsinglewallbulkhead(
    elementsCollection=hm.Collection(model, ent.Element, list(range(1, 9890))),
    domElementsCollection=hm.Collection(model, ent.Element, list(8396, 8418)),
    normal=[0, 0, -1],
    plane_point=[42.6, -21.9, 223.9],
    flange_width=32.0,
    mesh_elem_size=3.0,
    thickness=2.0,
    offset=0.0,
