Model.hm_getdistancefromnearestline#
Model.hm_getdistancefromnearestline(points, lineList)#
Gets the distance of the given point from the nearest line with IDs specified as arguments.
Parameters:
  • points (hwDoubleList) – The list of x, y, z coordinates of the point.
  • lineList (hwIntList) – List of line IDs.
Returns:
  • hwReturnStatus - Status object
  • HmQueryResult - Result object containing the output values:
    • closestLineDist (double) - the distance to the closest line
    • line (Entity) - the ID of the closest line
Examples#
Get closest to the point with coordinates ( 10 , 20 , 30 ) point on the line with ID 13#
import hm
import hm.entities as ent
model = hm.Model()
_, result = model.hm_getdistancefromnearestline(points=[10.0, 20.0, 30.0], lineList=[13])
print("closestLineDist", result.closestLineDist)
print("line", result.line)
Get closest line from the set with IDs 13 14 15#
import hm
model = hm.Model()
_, result = model.hm_getdistancefromnearestline(points=[10.0, 20.0, 30.0], lineList=[13, 14, 15])
