Model.midsurface_clear_plate_info#
Model.midsurface_clear_plate_info(collection, reserved1, reserved2)#
Deletes the plate and thickness information from selected surfaces, which was created via previous midsurface runs, or via plate edit functions.
Parameters:
  • collection (Collection) – The collection containing the surface entities to clear.
  • reserved1 (int) – Reserved for future use. Must be set to 0.
  • reserved2 (int) – Reserved for future use. Must be set to 0.
Example#
Delete the plate and thickness information from surfaces with IDs 5 - 7#
import hm
import hm.entities as ent
model = hm.Model()
surface_collection = hm.Collection(model, ent.Surface, list(range(5, 8)))
model.midsurface_clear_plate_info(
    collection=surface_collection, reserved1=0, reserved2=0
