Model.attributeupdatestringarrayelementmark#
- Model.attributeupdatestringarrayelementmark(collection, identifier, solver, status, behavior, index, value)#
Updates one element of an attribute of type string array (
hwStringList()).- Parameters:
collection (Collection) – The collection containing the entities that owns the attribute.
identifier (int) – The identifier of the attribute.
solver (int) – The solver number of the attribute.
status (int) – The status of the attribute.
behavior (int) – The behavior of the attribute.
index (int) – Index into the array (first index is zero).
value (hwString) – The value of the array element.
Example#
Update the load collector with ID 74 , 80 in * IMPERF_NRES_STR * dataname (identifier=11344) in Optistruct profile by set attribute * LAST * at second element of the array#import hm import hm.entities as ent model = hm.Model() # Finding the IMPERF_NRES_STR identifier using the hm_attributeidentifier function _, r = model.hm_attributeidentifier( entity_type=ent.Loadcol, entity_id=74, attribute_name_or_id="IMPERF_NRES_STR" ) # Setting the dataname model.attributeupdatestringarrayelementmark( collection=hm.Collection(model,ent.Loadcol, [74, 80]), identifier=r.id, solver=1, status=2, behavior=0, index=1, value='LAST', )
