Model.modent_registerconstraintruleoptions#
- Model.modent_registerconstraintruleoptions(modular_entity_type, modular_entity_action, independent_entity_type, dependent_entity_type, add_behavior_for_dependent_entity_type, add_behavior_for_shared_dependent_entity_type)#
Registers a list of options that control the behavior of add/move/remove operations for a modular entity. Valid entity combinations are:
Independent Entity Types
Dependent Entity Types
beamsectcols
beamsects
components
elements
components
materials
components
nodes
components
properties
loadcols
loads
materials
curves
properties
materials
systcols
systems
vectorcols
vectors
- Parameters:
modular_entity_type (EntityFullType) – The type of modular entity. Valid entity types are subsystems.
modular_entity_action (int) –
The type of modular entity action:
1 - Reset to defaults.
2 - Add/move/remove.
independent_entity_type (EntityFullType) – The type of independent entities to add/move/remove to/from modular entities.
dependent_entity_type (EntityFullType) – The type of dependent entities to add/move/remove to/from modular entities.
add_behavior_for_dependent_entity_type (int) –
0 - Do not add/move/remove to modular entities.
1 - Add/move/remove to modular entities.
add_behavior_for_shared_dependent_entity_type (int) –
0 - Do not add/move/remove independent entities to modular entities if they have any dependent entities shared with other modular entities.
1 - Do not add/move/remove dependent entities to modular entities if they are shared with other modular entities.
2 - Add/move/remove dependent to modular entities if they are shared with other modular entities.
Examples#
When adding/moving/removing components to subsystems, add/move/remove properties and shared properties#import hm import hm.entities as ent model = hm.Model() model.modent_registerconstraintruleoptions( modular_entity_type=ent.Subsystem, modular_entity_action=2, independent_entity_type=ent.Component, dependent_entity_type=ent.Property, add_behavior_for_dependent_entity_type=1, add_behavior_for_shared_dependent_entity_type=2, )
When adding/moving/removing components to subsystems, add/move/remove nodes, but prevent the action if there are any nodes shared with other subsystems#import hm import hm.entities as ent model = hm.Model() model.modent_registerconstraintruleoptions( modular_entity_type=ent.Subsystem, modular_entity_action=2, independent_entity_type=ent.Component, dependent_entity_type=ent.Node, add_behavior_for_dependent_entity_type=1, add_behavior_for_shared_dependent_entity_type=0, )
