Model.gapelementupdate#
- Model.gapelementupdate(collection, property, name, vectorid, Update)#
Updates the property pointer of gap elements.
- Parameters:
collection (Collection) – The collection containing the input gap element entities.
property (hwString) – The name of the property to which the gap elements should point.
name (Entity) – The object describing the orientation vector entity associated with the gap element.
vectorid (int) – The orientation vector ID associated with the gap element.
Update (int) – TBD
Example#
Create a gap element between node 5 and node 245 with property gapprop, without an orientation vector#import hm import hm.entities as ent model = hm.Model() elems = hm.Collection(model, ent.Element, "config=70") model.gapelementupdate(collection=elems, property="gapprop", name=None, vectorid=1)
