Model.hm_diffencodings#
Model.hm_diffencodings(encodings1, encodings2, encoding_algorithm=0, sphhar_bandwidth=16, sphhar_falloff=2.828427, sphhar_radii=32, sphhar_resolution=64)#
Calculates the distance between two encoded lists representing shapes of geometries. The geometries can be CAD, FE or a mixture. Typically this is the Euclidean distance normalized by the number of entries in the encoding. The encodings are generated by Model.hm_encodeshape().
Parameters:
  • encodings1 (hwDoubleList) – The first list of encodings generated by Model.hm_encodeshape().
  • encodings2 (hwDoubleList) – The second list of encodings generated by Model.hm_encodeshape().
  • encoding_algorithm (int) –
    The optional encoding algorithm to use. Valid values are:
    0 - Spherical harmonics (default)
  • sphhar_bandwidth (int) – Optional, valid for encoding_algorithm 0. (default=16)
  • sphhar_falloff (double) – Optional, valid for encoding_algorithm 0. (default=2.828427)
  • sphhar_radii (int) – Optional, valid for encoding_algorithm 0. (default=32)
  • sphhar_resolution (int) – Optional, valid for encoding_algorithm 0. (default=64)
Returns:
Example#
Calculate and diff the encodings from all surfaces against all elements#
import hm
import hm.entities as ent
model = hm.Model()
_, result = model.hm_encodeshape(entity_collection=hm.Collection(model, ent.Surface))
x = result.encoding
_, result = model.hm_encodeshape(entity_collection=hm.Collection(model, ent.Element))
y = result.encoding
_, result = model.hm_diffencodings(encodings1=x, encodings2=y)
print("distance", result.distance)
