Model.springsosupdate#
- Model.springsosupdate(collection, property_flag, property_name, vector_flag, vector_entity, direction_node_entity, orient_x, orient_y, orient_z, orient_comps_flag, system_entity, update_orient_flag)#
Updates a spring element using various orientation methods. The orientation may be specified using either
vector_entity,direction_node_entity,system_entityor individual components (orient_x,orient_y,orient_z).- Parameters:
collection (Collection) – The collection containing the spring element entities to update.
property_flag (int) –
0 - Do not update
property_name.1 - Update
property_name.property_name (hwString) – The name of the property to assign to the element.
vector_flag (int) –
0 - Do not update the orientation vector.
1 - Update the orientation vector.
vector_entity (Entity) – The object describing the orientation vector entity assigned to the element.
direction_node_entity (Entity) – The object describing the direction node entity assigned to the element.
orient_x (double) – The x-component of the orientation vector.
orient_y (double) – The y-component of the orientation vector.
orient_z (double) – The z-component of the orientation vector.
orient_comps_flag (int) –
0 - Do not use individual components to define the orientation.
1 - Use individual components to define the orientation.
system_entity (Entity) – The object describing the orientation system entity assigned to the element.
update_orient_flag (int) –
0 - Do not update the orientation vector’s component or system.
1 - Update the orientation vector’s component or system.
Example#
Update spring element with IDs 16, 17, and 18 to have property “sprate”, and an orientation vector with components (10.0, 11.0, 12.0)#import hm import hm.entities as ent model = hm.Model() model.springsosupdate( collection=hm.Collection(model, ent.Element, [16, 17, 18]), property_flag=1, property_name="sprate", vector_flag=1, vector_entity=None, direction_node_entity=None, orient_x=10.0, orient_y=11.0, orient_z=12.0, orient_comps_flag=1, system_entity=None, update_orient_flag=1, )
