Model.hm_wadlinesgetgridpointsleg#
Model.hm_wadlinesgetgridpointsleg(height, spacing=100.000000, version=DBL_MAX, end_gap=50.000000, clearance=75.000000, height_option=DBL_MAX, max_depth=10.000000, method=0)#
Returns grid points for either upper or lower leg impact analysis. The output is a series of four numbers for each grid point. The first number will be the column value, such as -2. The next three numbers will be the x, y, and z values of the grid point. It will use the front entities set using Model.hm_wadlinessetentities_bycollection() or Model.hm_wadlinessetentities_bymode() and the corner_angle set with Model.hm_wadlinessetparameters() to determine the “Corner of Bumper.” If Model.hm_wadlinessetbumper() has been used, the outermost ends of those entities will be determined. All points for the internal bumper reference line will fit laterally between either the “Corner of Bumper” or the outermost ends of the bumper entities, whichever is larger. This is the “Edge of Bumper Test Zone.”
For version 7.0, the front reference line will be used to determine upper leg grid points and the upper bumper reference line will be used to determine lower leg grid points.
For version 8.0, a WAD line of a specified distance will be used for the upper leg grid points and the internal bumper reference line will be used to determine the lower leg grid points. Note that the Model.hm_wadlinesgetinternalbumperline() API does not need to be called prior to calling this API. If the internal bumper reference line has not been generated it will automatically be calculated and used.
Note that not all options below are used for every version and upper/lower option.
Parameters:
  • height (int) –
    0 - Lower leg
    1 - Upper leg
  • spacing (double) – The lateral distance, starting from the vehicle center line, at which the points will be placed.
  • version (double) – Used for Euro NCAP protocol, 7.0, 8.0 or 8.2.
  • end_gap (double) – For the lower leg (height=0), if the distance between the last grid point placed at the given spacing value and the Edge of Bumper Test Zone is greater than end_gap, an additional grid point is placed at end_gap distance away from the last grid point. For the upper leg (height=1), any grid points placed within the end_gap distance of the Edge of Bumper Test Zone are removed. Default 50.0.
  • clearance (double) – Only used for the upper leg (height=1) for version 8.0. If the distance between the Edge of Bumper Test Zone and the last grid point is greater than the clearance, an additional grid point is placed at end_gap distance inboard of the end of the Edge of Bumper Test Zone. Default 75.0.
  • height_option (double) –
    For the upper leg (height=1), place the distance of the WAD line to be used in this field. Default 775.0.
    For the lower leg (height=0), place the maximum height of the internal bumper reference line in this field. Default 520.0.
  • max_depth (double) – For the lower leg (height=0), sets the maximum depth of the internal bumper reference line (the maximum rearward distance a point can be from the first point of contact and still be used to find the height of the bumper entities) (default 10.0). This is unused for the upper leg (height=1).
  • method (int) –
    The method to use for measuring. If left blank and Model.hm_wadlinessetoptions() has been used to set the Model.protocol_method, that value is used.
    0 - Euro NCAP (default if not specified)
    1 - Homologation
    2 - ECER
    3 - UN-R127 for corners, Euro NCAP elsewhere
Returns:
Examples#
Setup and extract WAD lines data#
import hm
import hm.entities as ent
model = hm.Model()
model.hm_wadlinesinit()
model.hm_wadlinessetparameters(
    side_angle=45.0,
    front_angle=50.0,
    spacing=100.0,
    rear_reference_radius=100.0,
    reference_resolution=50.0,
    upper_bumper_angle=20.0,
    lower_bumper_angle=25.0,
    corner_angle=60.0,
model.hm_wadlinessetaxes(
    origin=[0.0, 0.0, 182.0], forwardvec=[-1.0, 0.0, 0.0], leftvec=[0.0, -1.0, 0.0]
comps1 = hm.Collection(
    model, ent.Component, ids=[100000199, 100000200, 290000007, 410000016, 411000016, 420000004, 420000005, 420000006, 420000007, 420000008, 420000009, 420000010, 420000011, 420000012, 420000013, 420000014, 420000015, 420000016,420000019, 420000020 ]
comps2 = hm.Collection(model, ent.Component, ids=[100000003, 100000010, 100000022, 100000113])
model.hm_wadlinessetentities_bycollection(frontEntities=comps1, rearEntities=comps2)
components = hm.Collection(model, ent.Component, ids=[407000001, 407000002])
model.hm_wadlinessetbumper(entities=components)
_,resultlist = model.hm_wadlinesgetgridpointsleg(height=0, spacing=100.0, version=7.0 )
model.hm_wadlinesgetgridpointsleg(height=1, spacing=100.0, version=7.0 )
model.hm_wadlinesgetgridpointsleg(height=0, spacing=100.0, version=8.0 )
model.hm_wadlinesgetgridpointsleg(height=1, spacing=100.0, version=8.0 )
model.hm_wadlinesend()
for result in resultlist:
    print("columnIndex",result.columnIndex)
    print("pointCoordinates",result.pointCoordinates)
