Model.CE_UpdateCustomMessage#
Model.CE_UpdateCustomMessage(id, message_code)#
Attaches a custom error message to a connector.
Parameters:
  • id (unsigned int) – The ID of the connector to update.
  • message_code (unsigned int) –
    This is the message code as specified in the Connector_Message.txt file, which is available in the HyperMesh installation directory.
    Contains code-message pairs (i.e. for each code a user-defined message is available). You can edit/add messages to this file and provide the message code for this argument.
Example#
Attach a message to connector with ID 100#
import hm
import hm.entities as ent
model = hm.Model()
# The Connector_Message.txt file contains the following lines of code-message pairs:
# 11110 "Connector failed to create proper system."
# 11111 "Not a valid tag as link."
# 11112 "CE link does not have properties."
# Attach the first message to connector with ID 100:
model.CE_UpdateCustomMessage(id=100, message_code=11110)
