Model.extract_skeleton#
- Model.extract_skeleton(collection, resolution, prune_threshold=0.0, collapse_threshold=0.0, fill_holes=0.0, is_model_2d=0, symmetry_id=Entity(), symmetry_plane_base=hwDoubleList(), symmetry_plane_normal=hwDoubleList())#
This function extracts the skeleton of a 3D model, representing it as a group of 1D elements. The refinement level of the skeleton is determined by the resolution parameter. Additionally, branches and individual 1D elements below specified length thresholds can be pruned or collapsed.
Before calling this command, it is recommended to fill all larger gaps and holes in the model. If this is not done, the command will automatically fill gaps and holes with a maximum width of 4 times the resolution provided. The patches used to fill these gaps and holes are organized in a separate component named “^Patch”.
- Parameters:
collection (Collection) – The collection containing the input entities. Valid entity classes are elements, components, parts, surfaces, and solids.
resolution (double) – The resolution determining the refinement level of the skeleton. The value must be a positive double, typically small compared to the general dimensions of the input model.
prune_threshold (double) – The length threshold below which branches consisting of one or more 1D elements will be deleted. The value must be a positive double.
collapse_threshold (double) – The length threshold below which individual 1D elements will be collapsed. The value must be a positive double.
fill_holes (double) – Reserved for future development
is_model_2d (unsigned int) – Reserved for future development
symmetry_id (Entity) – Reserved for future development
symmetry_plane_base (hwDoubleList) – Reserved for future development
symmetry_plane_normal (hwDoubleList) – Reserved for future development
Example#
Extract the skeleton of all displayed elements using default values#import hm import hm.entities as ent model = hm.Model() displayed_elems = hm.CollectionByDisplayed(model, ent.Element) model.extract_skeleton( collection=displayed_elems, resolution=0.1, )
Extract the skeleton with a resolution of 10, collapse threshold of 20, and prune threshold of 100#import hm import hm.entities as ent model = hm.Model() displayed_solids = hm.CollectionByDisplayed(model, ent.Solid) model.extract_skeleton( collection=displayed_solids, resolution=10.0, collapse_threshold=20.0, prune_threshold=100.0 )
