Model.multi_surfs_lines_merge#
Model.multi_surfs_lines_merge(surf_collection, line_collection, options, tolerance=0.0)#
This function takes input surfaces, finds intersections between them, creates trimming lines at the intersections, and equivalences the resulting surface edges; thus creating a topologically valid body from possibly overlapping surfaces.
Optionally, a set of lines specified line_collection can be used to create additional edges on selected surfaces within proximity of those lines. The tolerance value is used to calculate proximity and equivalence between edges.
Parameters:
  • surf_collection (Collection) – The collection containing the input surfaces.
  • line_collection (Collection) – The collection containing the optional input line entities. If not required, reference an empty collection.
  • options (int) – Reserved for future development.
  • tolerance (double) – The proximity tolerance value. If not set, the value of global cleanup tolerance is used.
Examples#
Find intersections and merge surfaces with IDs 30 and 31 into a single body#
import hm
import hm.entities as ent
model = hm.Model()
model.multi_surfs_lines_merge(
    surf_collection=hm.Collection(model, ent.Surface, [30, 31]),
    line_collection=hm.Collection(model, ent.Line, populate=False),
    options=0,
Find intersections and merge all displayed surfaces into a single body#
import hm
model = hm.Model()
    surf_collection=hm.CollectionByDisplayed(model, ent.Surface),
    options=0,
Trim the surface with ID 31 by free line with ID 9 use the value of 0.1 as a proximity tolerance#
import hm
model = hm.Model()
    surf_collection=hm.Collection(model, ent.Surface, [31]),
    line_collection=hm.Collection(model, ent.Line, [9]),
    options=0,
    tolerance=0.1
