Model.hm_ispointinsidesolidelem#
- Model.hm_ispointinsidesolidelem(x, y, z, element)#
Returns 1 if the point is found to be inside the solid element and 0 otherwise.
- Parameters:
x (double) – The x coordinate of the point.
y (double) – The y coordinate of the point.
z (double) – The z coordinate of the point.
element (Entity) – The object describing the solid element entity.
- Returns:
hwReturnStatus- Status objectHmQueryResult- Result object containing the output values:isInside (bool)
Example#
Check whether the point with coordinates 10 , 20 , 30 is inside the solid element with ID 1#import hm import hm.entities as ent model = hm.Model() _, result = model.hm_ispointinsidesolidelem(x=10, y=20, z=30, element=ent.Element(model, 1)) print("isInside", result.isInside)
