Model.mechcontructfromedi#
- Model.mechcontructfromedi(mode, param)#
Creates objects needed for solving enabled mechanisms, such as applying positions or moving bodies.
The mechanism must have the enabled flag set to true for this to be possible.
- Parameters:
mode (int) –
The mode for mechanism operations:
0 - Move
2 - Apply position
param (int) – The position ID to use when mode is 2
Examples#
Set up mechanism with ID 1#import hm import hm.entities as ent model = hm.Model() model.mechcontructfromedi(mode=0,param=0)
Apply position with ID 3 on mechanism with ID 1#import hm import hm.entities as ent model = hm.Model() model.mechcontructfromedi(mode=2,param=3) model.mechapplyediposition(mode=1,run_solver=0)
