Model.hm_finddeviation#
- Model.hm_finddeviation(source_collection, target_collection, tolerance_value)#
Finds and returns the deviating component pairs data for a given set of selected components.
- Parameters:
source_collection (Collection) – The collection containing the source entities. Currently supported for components only.
target_collection (Collection) – The collection containing the target entities. Currently supported for components only.
tolerance_value (double) – The tolerance value.
- Returns:
hwReturnStatus- Status objectHmQueryResult- Result object containing the output values:sourceString (str)
sourceComponent (Entity) - The source component entity.
targetString (str)
targetComponent (Entity) - The target component entity.
unmatchString (str)
unmatch (double) - The approximate percentage of unmatched area between the two components.
deviationdataString (str)
deviationdata (
HmQueryResultList)-Result list object containingHmQueryResultobjects with the following output data:sourcePointCoordinates (numpy.ndarray) - The coordinates of the point on the source component where the deviation occurs.
targetPointCoordinates (numpy.ndarray) - The coordinates of the point on the target component where the deviation occurs.
sourceSurface (Entity) The surface entity on the source component that contains the source point.
targetSurface (Entity) - The surface entity on the target component that contains the target point.
deviationDistance (double) - The distance between the source point and the target point.
Example#
Get the deviation information between components with IDs 81 and 88 use a tolerance of 0.01#import hm import hm.entities as ent model = hm.Model() _ , result = model.hm_finddeviation( source_collection=hm.Collection(model, ent.Component, [81]), target_collection=hm.Collection(model, ent.Component, [88]), tolerance_value=0.01 ) print("sourceString", result.sourceString) print("sourceComponent", result.sourceComponent) print("targetString", result.targetString) print("targetComponent", result.targetComponent) print("unmatchString", result.unmatchString) print("unmatch", result.unmatch) print("deviationdataString", result.deviationdataString) deviationdata = result.deviationdata for data in deviationdata: print(sourcePointCoordinates, data.sourcePointCoordinates) print(targetPointCoordinates, data.targetPointCoordinates) print(sourceSurface, data.sourceSurface) print(targetSurface, data.targetSurface) print(deviationDistance, data.deviationDistance)
