Model.segmentsetaddfacesusingfacenumber#
- Model.segmentsetaddfacesusingfacenumber(name, collection, face_number, reverse_normals, element_id, option)#
Adds faces of elements using a specific face number to a segment set.
- Parameters:
name (hwString) – The name of the segment set to update.
collection (Collection) – The collection containing the element entities to add.
face_number (int) – The face number of the element (starting from 0).
reverse_normals (int) –
Create segment set:
0 - Along element normal
1 - Opposite element normal
element_id (int) – If non-zero, specifies the single element to use instead of
collection. Option must be set non-zero.option (int) – If non-zero, specifies to use
element_idinstead ofcollection.
Example#
Add elements with IDs 1 - 100 useface_number=2to segment set “ test “#import hm import hm.entities as ent model = hm.Model() # Creating a collection that contains the elements to add filter_add_elements = hm.FilterByEnumeration(ent.Element, list(range(1, 101))) add_elements_collection = hm.Collection(model, filter_add_elements) model.segmentsetaddfacesusingfacenumber( name="test", collection=add_elements_collection, face_number=2, reverse_normals=0, element_id=1, option=0, )
