Model.hm_getmaxgapwidth#
Model.hm_getmaxgapwidth(entity_list1, entity_list2)#
Returns the approximate maximum distance between a pair of node lists. This is useful for determining the gap width to be used for filling the gap between the node lists.
Parameters:
  • entity_list1 (EntityList) – A list containing the entity objects of the first nodes.
  • entity_list2 (EntityList) – A list containing the entity objects of the second nodes.
Returns:
Example#
Get the maximum gap width between two node lists#
import hm
import hm.entities as ent
model = hm.Model()
nodes1 = [ent.Node(model, n) for n in range(1,21) ]
nodes2 = [ent.Node(model, n) for n in range(45, 81) ]
_, result = model.hm_getmaxgapwidth(
    entity_list1=nodes1,
    entity_list2=nodes2
print("maximumGap: ", result.maximumGap)
