Model.solidmeshwithsurfaces#
- Model.solidmeshwithsurfaces(type, source, dest, along, genelems, elements, density, biasstyle, biasing)#
Creates a mesh of solid elements by first extruding an existing 2D finite element mesh, and then mapping the extruded mesh into a volume.
- Parameters:
type (int) –
Identifies which type of geometry is being supplied. Valid values are:
0 - Source and destination
1 - Source and along
2 - Source, destination, and along
source (Collection) – The collection containing the geometric data of the source face. Valid entities are nodes, lines and surfaces.
dest (Collection) – The collection containing the geometric data of the destination face. Valid entities are nodes, lines and surfaces.
along (EntityList) – The collection containing the geometric data of the along faces. Valid entities are lines and surfaces.
genelems (int) – Currently not used.
elements (Collection) – The collection containing the element entities which are to be mapped into the volume.
density (int) – The number of elements to be created between the source and destination faces.
biasstyle (int) – The type of biasing to use.
biasing (double) – The biasing intensity value.
