Model.blmesh_2d_computeblthickness1#
- Model.blmesh_2d_computeblthickness1(base_collection, num_layers, first_layer_thickness, growth_rate, core_to_BL_ratio, corner_factor, DefaultBLSelection='')#
Used to generate boundary layer thickness on boundary nodes with specified parameters and default BL/nonBL type definition.
Model.blmesh_2d_input_bl()andModel.blmesh_2d_input_nonbl()should be used before calling this function.- Parameters:
base_collection (Collection) – The collection containing the entities to be used for the base to generate BL thickness. Valid entities are only elements.
num_layers (int) – The number of boundary layers to generate.
first_layer_thickness (double) – The thickness value of the first layer.
growth_rate (double) – The growth rate of the boundary layers.
core_to_BL_ratio (double) – Ratio of core mesh to BL thickness, which is used for BL reduction.
corner_factor (double) – A dimensionless value used for corner management. The range is 0.1-1.0 for thinner BL thickness, and 1.0-10.0 for thicker BL thickness.
DefaultBLSelection (hwString) – Default BL/non-BL selection for all boundary edges. Valid values are With_BL, Without_BL_fixed, Without_BL_remesh.
Example#
Create a 5 layer boundary mesh from elements with IDs 10 - 100 , with the first layer be 0.15 thick and agrowth_rateof 1.2 , acore_to_BL_ratioof 2.5 , acorner_factorof 1.1 , use boundary layer elements with 10 and 11 as fixed and 12 and 13 as float , and use non - boundary layer elements with ID 1 and 2 as fixed and 5 and 6 as float#import hm import hm.entities as ent model = hm.Model() # Boundary layer elements blFixedEl_collection = hm.Collection(model, ent.Element, [10, 11]) blFloatEl_collection = hm.Collection(model, ent.Element, [12, 13]) model.blmesh_2d_input_bl( fixed_collection=blFixedEl_collection, float_collection=blFloatEl_collection ) # Non-Boundary layer elements nonBlFixedEl_collection = hm.Collection(model, ent.Element, [1, 2]) nonBlFloatEl_collection = hm.Collection(model, ent.Element, [5, 6]) model.blmesh_2d_input_nonbl( fixed_collection=nonBlFixedEl_collection, float_collection=nonBlFloatEl_collection ) # Generate the Boundary layer mesh base_elem_collection = hm.Collection(model, ent.Element, list(range(10, 101))) model.blmesh_2d_computeblthickness1( base_collection=base_elem_collection, num_layers=5, first_layer_thickness=0.15, growth_rate=1.2, core_to_BL_ratio=2.5, corner_factor=1.1, DefaultBLSelection="With_BL", )
