Model.surfaceprimitivefromlines#
Model.surfaceprimitivefromlines(collection, surf_type, tol_mode, tol, options)#
Takes input lines and uses them as targets to construct surface of specified primitive type. Optionally, tolerance value can be specified to reject surface that does not fit input lines.
Parameters:
  • collection (Collection) – The collection containing the line entities.
  • surf_type (int) –
    The type of primitive surface to create. Valid values are:
    1 - plane
    2 - sphere
    3 - cylinder
    4 - cone
    5 - general quadric surface
    For surf_type=4, if a cylinder can be fit to the input entities, it will be created instead of a cone.
  • tol_mode (int) –
    0 - Tolerance is not used, best possible surface is found for any input set of points.
    1 - Tolerance specified by tol parameter is used to reject surface that does not fit input points.
  • tol (double) – Tolerance value used to accept generated surface. Not used if tol_mode=0. Negative value can be set to specify that the global value of the geometry cleanup tolerance set use hm.setoption(cleanup_tolerance=...).
  • options (int) –
    Flags that indicate different modes.
    Bit values are used and the value is calculated as (Bit0 + 2*Bit1). Valid Bit options are:
    Bit0
    Trimming mode. Valid values are:
    0 - An untrimmed surface is created.
    1 - Created surface is trimmed by input lines and automatically stitched to adjacent surfaces.
    In this case, the value of tol_mode should be set to 1.
    Bit1
    Specifies how entities are organized into components. Valid values are:
    0 - Surface is created in the current component.
    1 - Surface is created in the most common input lines component.
    Show Bit value calculator
    Radio Button Table
    Option Name Value
    Trimming mode (Bit0)
    Specifies how entities are organized into components (Bit1)
    Calculated argument value: 0
Examples#
Create a cone surface that fits all displayed lines in the best possible way#
import hm
import hm.entities as ent
model = hm.Model()
model.surfaceprimitivefromlines(
    collection=hm.CollectionByDisplayed(model, ent.Line),
    surf_type=4,
    tol_mode=0,
    tol=0.0,
    options=0,
Try to create a sphere that fits the lines with IDs 1 through 8 with a deviation not larger than 0.02 , and trim the resulted surface with the input lines#
import hm
model = hm.Model()
# Creating a collection that contains the lines with IDs 1-8
filter_lines = hm.FilterByEnumeration(ent.Line, list(range(1, 9)))
lines_collection = hm.Collection(model, filter_lines)
    collection=lines_collection, surf_type=2, tol_mode=1, tol=0.02, options=1
