Model.hm_attributetype#
Model.hm_attributetype(attribute_id)#
Returns the attribute type number of an attribute for the current template. If the attribute is not an attribute from the current template, an error is returned.
Parameters:
attribute_id (int) – The ID of the attribute to query. The attribute must be in the current template.
Returns:
  • hwReturnStatus - Status object
  • HmQueryResult - Result object containing the output values:
    • type (int) - The type can be one of the following values:
      1 - integer
      2 - double
      3 - string
      4 - 1D integer array
      5 - 1D double array
      6 - entity
      7 - (not supported)
      8 - (not supported)
      9 - 2D integer array
      10 - 2D double array
      11 - string array
      12 - 1D entity array
      13 - 2D entity array
Example#
Get the attribute type number of the attribute with ID 149 for the LS - DYNA template#
import hm
import hm.entities as ent
model = hm.Model()
_, result = model.hm_attributetype(attribute_id=149)
print("Attribute Type:", result.type)
