Model.setisosurfaceparameters#
- Model.setisosurfaceparameters(on, legendbased, value, addfacesabove, transparent, constantcolor, color)#
Sets the display parameters of the isosurface.
- Parameters:
on (int) – A boolean (0 or 1) value to turn the isosurface on or off.
legendbased (int) – A boolean (0 or 1) value to determine if the isosurface is legend based or value based.
value (double) – The value of the value-based isosurface.
addfacesabove (int) – A boolean (0 or 1) value to add the “faces above” to the isosurface.
transparent (int) – A boolean (0 or 1) value to turn on transparency on the “faces below” the iso value.
constantcolor (int) – A boolean (0 or 1) value to display the isosurface in a user-specified.
color (int) – The color of the isosurface.
Example#
Display the isosurfaces with legend#import hm import hm.entities as ent model = hm.Model() model.setisosurfaceparameters( on=1, legendbased=1, value=0, addfacesabove=0, transparent=0, constantcolor=0, color=0, )
