Model.morphnodesshapeenvelope#
- Model.morphnodesshapeenvelope(e_collection, f_collection, a_shape, integ, mbias, fbias, mult, envelope, undisplayed)#
This function will apply the specified shape to the mesh be a factor specified by
mult. The fixed nodes are held in place and the affected elements (or all unfixed nodes in the model ifintegis 3 or 6) are stretched according to the value ofinteg.Temporary handles are created for all moving and fixed nodes to determine the stretching of the affected elements.
If
integ=0, a general domain is temporarily created for the affected elements.If
integ=1, the domains currently in the model are used.If
integ=2, 1D, 2D, 3D, and edge domains are temporarily created for the affected elements but the 2D domains are not partitioned.If
integ=3, then handle influences are applied using a spatial relationship rather than through a domain.If
integ=4, only the selected moving nodes are moved and all others are held fixed.If
integ=5, 1D, 2D, 3D, and edge domains are temporarily created for the affected elements and the 2D domains are partitioned. Any handles created due to partitioning are moved based on their distance from the moving and fixed nodes.If
integ=6, then handle influences are applied using the Kriging algorithm.If
integ=7, then handle influences extend only up to a given distance (if envelope is positive) or a given multiple of the applied perturbations (if envelope is negative) away from the moving nodes.The bias factors function as they would for handles except that all moving nodes will have the
mbiasvalue and all fixed nodes will have thefbiasvalue.If
integis set to 3, 6, or 7, nodes on undisplayed elements and components can be morphed, fixed, or excluded depending on the value ofundisplayed.- Parameters:
e_collection (Collection) – The collection containing the affected element entities.
f_collection (Collection) – The collection containing the fixed node entities.
a_shape (Entity) – The object describing the entity.
integ (int) –
0 - Free edges (a single general domain)
1 - Use existing domains
2 - Inferred edges (1D, 2D, 3D, and edge domains - no partitioning)
3 - Morph all nodes using a proximity algorithm
4 - Morph all moving nodes and fix the unselected nodes
5 - Partitioned edges (1D, 2D, 3D, and edge domains with partitioning)
6 - Morph all nodes using the Kriging algorithm
7 - Morph all nodes within an envelope around the moving nodes
mbias (double) – Bias factor of moving nodes.
fbias (double) – Bias factor of fixed nodes.
mult (double) – The multiplication factor for the shape.
envelope (double) –
If positive, all nodes beyond the given distance away from the moving nodes will be fixed.
If negative, all nodes beyond a distance calculated by multiplying the total perturbation of each moving node by the absolute value of the envelope and extended away from each moving node will be fixed.
If
integ=7, the calculated distance defines an envelope around the moving nodes within which the morphing of those nodes will linearly taper from fully matching the nearest moving node to zero at the edge of the envelope. If any fixed nodes are within the envelope, they will also reduce the morphing of nearby nodes.undisplayed (int) – Reserved for future development. Set it always to 0.
Example#
Apply a shape ID 14 with multiplication factor 3.0 on nodes with IDs 21 , 22 , and 23 , and stretch all the elements in the model use the exist domains#import hm import hm.entities as ent model = hm.Model() model.morphnodesshapeenvelope( e_collection=hm.Collection(model, ent.Element), f_collection=hm.Collection(model, ent.Node, [21, 22, 23]), a_shape=ent.Shape(model, 14), integ=1, mbias=1.0, fbias=1.0, mult=3.0, envelope=0.0, undisplayed=0, )
