Model.optimized_elements_remesh2#
Model.optimized_elements_remesh2(collection, criteria_file, elem_size, elem_type, feature_angle, vertex_angle, comp_mode, break_flag, algorithm)#
Remeshes elements with the selection of the best meshing algorithm and optimization of node positions.
Parameters:
  • collection (Collection) – The collection containing the element entities to remesh.
  • criteria_file (hwString) – The path and file name of the criteria file. Set the value to “dummy” to use the default file.
  • elem_size (double) – The default element size used to calculate element densities along edges, when necessary. Element sizes along shared edges cannot be changed.
  • elem_type (int) –
    The type of elements to create. Valid values are:
    0 - trias
    1 - quads
    2 - mixed
    3 - right trias
    4 - quads only
  • feature_angle (double) – The angle, in degrees, specifying the feature lines. This is approximately the minimal internal angle between the elements adjacent to a feature line. Valid values are between 18-90 degrees.
  • vertex_angle (double) – The angle between two edge segments when a vertex is created.
  • comp_mode (int) –
    A flag that specifies how the elements are organized. Valid values are:
    0 - Elements are created in the current component.
    1 - Elements are created in the same component as their parent surface(s).
  • break_flag (int) –
    Determines if connectivity will be broken along shared edges between elements when a different element size is chosen. Valid values are:
    0 - Do not break connectivity.
    1 - Break connectivity.
  • algorithm (int) –
    Determines the algorithm for meshing. Valid values are:
    0 - Standard meshing
    1 - Meshing with flow “align” control
    3 - Meshing with flow “align” and “size” control
Example#
Re - mesh the displayed elements with element size 10 , mixed elements type , and optimize node positions use * default * criteria file (criteria_file="dummy " ) , feature and vertex angle of 30 degrees , and meshing flow with align and size control#
import hm
import hm.entities as ent
model = hm.Model()
remesh_elems_col = hm.CollectionByDisplayed(model, ent.Element)
model.optimized_elements_remesh2(
    collection=remesh_elems_col,
    criteria_file="dummy",
    elem_size=10.0,
    elem_type=2,
    feature_angle=30.0,
    vertex_angle=30.0,
    comp_mode=1,
    break_flag=0,
    algorithm=3,
