Model.nodelistbypath2#
Model.nodelistbypath2(nodeA, nodeB, entitylist, ignoreEdgeFlag, search_factor=1)#
Creates a node path from the starting node to the ending node.
Parameters:
  • nodeA (Entity) – The object describing the first node entity.
  • nodeB (Entity) – The object describing the second node entity.
  • entitylist (EntityList) – A list containing the node entity objects to populate.
  • ignoreEdgeFlag (int) –
    0 - If both nodeA and nodeB lie on free edges, the path will follow free edges where possible. Otherwise, the shortest path is returned. This is the same as running nodelistbypath().
    1 - Always return the shortest path.
  • search_factor (double) – By default, only a subsection of the model is considered when creating the node path. Increasing this value will increase the search area. Default value is 1.0.
Examples#
Determine the path between nodes with IDs 100 and 110 use the shortest path#
import hm
import hm.entities as ent
model = hm.Model()
entitylist = hm.EntityList(ent.Node, hm.hwUIntList([]))
model.nodelistbypath2(
    nodeA=ent.node(model, 100),
    nodeB=ent.Node(model, 110),
    entitylist=list,
    ignoreEdgeFlag=1,
Determine the path between nodes with IDs 100 and 110 use the shortest path consider the increase in search area by 20 percent#
import hm
model = hm.Model()
    entitylist=list,
    ignoreEdgeFlag=1,
    search_factor=1.2,
