Model.elementtestjacobian#
- Model.elementtestjacobian(collection, jacobian, outputcollection, dimension, contour, title)#
Tests 2D and 3D elements for whether or not they pass the Jacobian ratio element quality check, and puts those that fail on the specified
outputcollection.- Parameters:
collection (Collection) – The collection containing the element entities to test.
jacobian (double) – The value to use as a threshold beyond which elements should be considered to have failed the test.
outputcollection (Collection) – The collection containing the failed element entities.
dimension (int) –
A code telling to measure the dimension of:
2 - Measure 2D elements.
4 - Measure 3D elements.
contour (int) –
A code telling if should:
0 - Display the results of the test normally.
1 - Display the elements color coded by their ratings.
2 - Build a histogram showing the distribution of ratings.
title (hwString) – The title to label the curve in the histogram.
Example#
Test all displayed elements for a Jacobian ratio value less than 0.7#import hm import hm.entities as ent model = hm.Model() elems1 = model.CreateCollectionByDisplayed(ent.Element) elems2 = hm.Collection(model, hm.FilterByEnumeration(ent.Element, ids=hm.hwUIntList([]))) model.elementtestjacobian( collection=elems1, jacobian=0.7, outputcollection=elems2, dimension=2, contour=0, title="2D Element Jacobian" )
Note
The details of the Jacobian ratio element quality check can be found in the online help for the Check Elements panel.
