Model.morphconstraintupdatearcrad#
- Model.morphconstraintupdatearcrad(scollection, acollection, type, mcon, plane_normal, plane_base, dptr, radius, bound, arc, color)#
Updates a model type constraint based on the radius or arc length of an edge domain.
- Parameters:
scollection (Collection) – The collection containing the input shape entities.
acollection (Collection) – The collection containing the node or line entities.
type (int) –
0 - Measure radius or arc angle using domain
1 - Measure radius or arc angle using axis
2 - Measure radius or arc angle using line
3 - Measure radius or arc angle using node
mcon (Entity) – The morph constraint entity
plane_normal (hwTriple) – The hwTriple object defining the plane normal components. User can also supply a Python list of three doubles.
plane_base (hwTriple) – The hwTriple object defining the base point components of the plane. User can also supply a Python list of three doubles.
dptr (Entity) – The line entity of the edge domain
radius (double) – Constrained radius or arc angle
bound (int) –
-1 - Greater than specified angle
0 - Equal to specified angle
1 - Less than specified angle
arc (int) –
0 - Radius
1 - Arc angle
color (int) – The color of the constraint. Valid values are 1-64.
Example#
Update a model type constraint for the selected domain with the option of update the radius to be measured in the plane of the domain and the option of have the radius angle forced to be equal to the specified value .#import hm import hm.entities as ent model = hm.Model() model.morphconstraintupdatearcrad( scollection=hm.CollectionByInteractiveSelection(model, ent.Shape), acollection=hm.CollectionByInteractiveSelection(model, ent.Node), type=0, mcon=ent.Morphconstraint(model, 5), plane_normal=[1.0, 0.0, 0.0], plane_normal_base=[1.0, 0.0, 0.0], dptr=ent.Line(model, 21), radius=5.0, bound=0, arc=0, color=32, )
Note
If
arc=0, the radius will be constrained. Ifarc=1, the arc angle will be constrained.The shapes on the
scollectionwill be used to force the model into compliance with the specified constraint if possible.
