Model.loadcreateonentity#
Model.loadcreateonentity(collection, config, type, comp1, comp2, comp3, comp4, comp5, comp6)#
Creates a load (forces, temperature, moment, velocity, acceleration, or constraints) on nodes, fixed points (surface vertices or weld points), surface edges, and surfaces.
Parameters:
  • collection (Collection) – The collection containing the entities. Valid entities are nodes, points, surface edges(lines) and surfaces.
  • config (int) –
    The configuration of the load to apply. Valid values are:
    1 - Force
    2 - Moment
    3 - Constraint
    5 - Temperature
    6 - Flux
    8 - Velocity
    9 - Acceleration
  • type (int) – The type assigned to the load (as defined on the “load types” panel).
  • comp1 (double) – The component of the load being applied. For all configs except constraints (config=3), this component represents the load in x-direction.
  • comp2 (double) – The component of the load being applied. For all configs except constraints (config=3), this component represents the load in y-direction.
  • comp3 (double) – The component of the load being applied. For all configs except constraints (config=3), this component represents the load in z-direction.
  • comp4 (double) – The component of the load being applied. Applicable only for constraints (config=3).
  • comp5 (double) – The component of the load being applied. Applicable only for constraints (config=3).
  • comp6 (double) – The component of the load being applied. Applicable only for constraints (config=3).
Note
For constraints, all of the components are active unless they are set equal to -999999.0. All of the other components of the constraints are active in the respective directions.
For pressures, to create a pressure which is normal to the element, set all components to zero.
Example#
Apply a temperature of 0.0 degrees on a surface#
import hm
import hm.entities as ent
model = hm.Model()
surface_collection = hm.Collection(model, ent.Surface, [12])
model.loadcreateonentity(
    collection=surface_collection,
    config=5,
    type=1,
    comp1=0.0,
    comp2=0.0,
    comp3=0.0,
    comp4=0.0,
    comp5=0.0,
    comp6=0.0,
