Model.elementtestcellsquish#
- Model.elementtestcellsquish(collection, cell_squish, output_collection, dimension, contour, title)#
Tests 2D and 3D elements using the cell squish element quality check.
- Parameters:
collection (Collection) – The collection containing the element entities to be checked.
cell_squish (double) – The value to use as a threshold beyond which elements should be considered to have failed the test.
output_collection (Collection) – The collection containing the failed element entities.
dimension (int) –
A code telling to measure the dimension of:
2 - Measure 2D elements.
4 - Measure 3D elements.
contour (int) –
Flag that determines how the results are presented. Valid values are:
0 - Display the results of the test normally.
1 - Display the elements color coded by their ratings.
2 - Build a histogram showing the distribution of ratings.
title (hwString) – The title to label the curve in the histogram. Only required, if contour is 2.
Example#
Test all displayed elements for a cell squish of 0.5#import hm import hm.entities as ent model = hm.Model() elems1 = model.CreateCollectionByDisplayed(ent.Element) elems2 = hm.Collection(model, hm.FilterByEnumeration(ent.Element, ids=hm.hwUIntList([]))) model.elementtestcellsquish( collection=elems1, cell_squish=0.5, output_collection=elems2, dimension=0, contour=0, title="" )
