Model.xyplotcreatecomplex#
Model.xyplotcreatecomplex(plot, name, mode)#
Creates an extended or dual plot that contains two sub-plots.
Parameters:
  • plot (hwString) – The name of the plot to be created.
  • name (hwString) – The name of the plot from which the new plot obtains its default values.
  • mode (int) – Mode to select if will be an extended or dual plot.
Example#
Create a complex plot#
import hm
import hm.entities as ent
model = hm.Model()
model.xyplotcreatecomplex(
    plot="myplot", name="", mode=1
