Model.hm_getelementsqualityinfo#
- Model.hm_getelementsqualityinfo(elements, criteria_use_mode=1, failedElements=s_defaultCollection)#
Computes quality parameters for the specified selection of elements.
- Parameters:
elements (Collection) – The collection containing the input element entities.
criteria_use_mode (int) –
0 - The default quality criteria adjusted to the selected averaged element size are automatically created if the criteria do not exist.
1 - The quality criteria must be explicitly set beforehand. If the parameter is not given, 1 is used as the default value.
failedElements (Collection) – The output collection containing the failed element entities.
- Returns:
hwReturnStatus- Status objectHmQueryResult- Result object containing the output values:totalNumberOfElements (int) - Total number of elements
numberOfFailedElements (int) - Number of failed elements
qualityIndex (double) - Quality index
percentageOfFailedElements (double) - % of failed elements
percentageOfTrias (double) - % of trias elements
Example#
Get for all elements in the current model , the quality information#import hm import hm.entities as ent model = hm.Model() element_collection = hm.Collection(model, ent.Element) failed_elem_collection = hm.Collection(model, ent.Element, populate=False) _, result = model.hm_getelementsqualityinfo( elements=element_collection, failedElements=failed_elem_collection ) print("Total Number of Elements:", result.totalNumberOfElements) print("Number of Failed Elements:", result.numberOfFailedElements) print("Failed Elements IDs:", [e.id for e in failed_elem_collection]) print("Quality Index:", result.qualityIndex) print("Percentage of Failed Elements:", result.percentageOfFailedElements) print("Percentage of Trias:", result.percentageOfTrias)
