Model.multi_trim_by_offset_edges#
- Model.multi_trim_by_offset_edges(surfaces, lines, offset_distance=0, offset_count=1)#
Offsets the selected edges and trims the input surfaces using the offset edges. You have the option to offset the original edges with the same distance multiple times.
- Parameters:
surfaces (Collection) – The collection containing the input surface entities.
lines (Collection) – The collection containing the input line entities to be used for offsetting and trimming the input surfaces.
offset_distance (double) – The offset distance.
offset_count (int) – The number of offsets to be performed. The value should be greater than 0.
Example#
Trim surface with ID 2 by offset edges with IDs 10, 12, 14, 15 by distance 5.0, for 4 times#import hm import hm.entities as ent model = hm.Model() model.multi_trim_by_offset_edges( surfaces=hm.Collection(model, ent.Surface, [2]), lines=hm.Collection(model, ent.Line, [10, 12, 14, 15]), offset_distance=5.0, offset_count=4, )
