Model.hm_checkproximity#
Model.hm_checkproximity(collection, max_proximity, mode=1, check_side=3, proximity_scheme=1, proximity_by_edge=0, min_angle_limit=0, max_angle_limit=0)#
Checks proximity between input entities and returns list of entities within the specified proximity. The output depends on the mode argument as defined below.
Parameters:
  • collection (Collection) – The collection containing the entities.
  • max_proximity (double) – The maximum distance beyond which an entity is not considered.
  • mode (unsigned int) –
    1 - Global proximity (default)
    2 - Proximity between components (collection must contain components)
    3 - Self proximity within components (collection must contain components)
  • check_side (unsigned int) –
    1 - Check both sides of elements
    2 - Check only the element normal side
    3 - Check ‘outward volume’ side (default)
    4 - Check ‘inward volume’ side
  • proximity_scheme (unsigned int) –
    0 - Checks basic proximity along a ray from the element center along the normal direction.
    1 - Checks comprehensive proximity. Reports any proximity within an imaginary offsetted volume of the element (default).
  • proximity_by_edge (unsigned int) –
    0 - Ignores proximity for nearby edges (default)
    1 - Considers proximity for nearby edges.
  • min_angle_limit (double) – If the angle between the proximate element pairs is less than this value, such pairs are not reported.
  • max_angle_limit (double) – If the angle between the proximate element pairs is greater than this value, such pairs are not reported.
Returns:
For mode=1:
  • HmQueryResult - Result object containing the output values:
    • elements1 (EntityList) - The list of elements for which a proximity is found.
    • elements2 (EntityList) - The list of paired elements for the elements in elements1.
For mode=2 and mode=3:
    • data_by_component (HmQueryResultList) - Result list object containing HmQueryResult objects with the following output data:
      • component (Entity) - The component for which the proximity is checked.
Example#
Find proximity between all components using a max distance of 2.5#
import hm
import hm.entities as ent
model = hm.Model()
components = hm.Collection(model, ent.Component)
_, result = model.hm_checkproximity(
    collection=components,
    max_proximity=2.5,
    mode=1,
    min_angle_limit=10,
    max_angle_limit=80
print("Number of identified elements with proximity:", len(result.elements1))
print("Number of paired elements:", len(result.elements2))
Find proximity per component (mode=2) using a max distance of 2.5#
import hm
model = hm.Model()
    max_proximity=2.5,
    mode=2,
    min_angle_limit=10,
    max_angle_limit=80
for comp_result in result.data_by_component:
    print(f"Component ID: {comp_result.component.id}")
    print("Number of identified elements with proximity:", len(comp_result.elements1))
    print("Number of paired elements:", len(comp_result.elements2))
