Model.elementsaddnodesfixed#
- Model.elementsaddnodesfixed(elements_collection, nodes_collection)#
Marks the specified nodes of the old elements as fixed nodes (nodes that must be retained in the mesh to be created) before using the functions for remeshing/meshing by elements.
- Parameters:
elements_collection (Collection) – The collection containing the element entities that are considered for remeshing/meshing by elements.
nodes_collection (Collection) – The collection containing the node entities specifying the nodes to be retained in the new mesh.
Note
The use of this function implies that it will be followed by a function that performs remeshing/meshing by elements, such as:
Example#
Re - mesh the elements with IDs 154 , 155 , 158 , 159 , 160 , 161 , 164 , 165 , 339 , 341 , 343 , 345 , and 347 , and retain the nodes with IDs 210 , 277 , and 370 in the mesh to be created#import hm import hm.entities as ent model = hm.Model() remesh_elems_col = hm.Collection( model, ent.Element, [154, 155, 158, 159, 160, 161, 164, 165, 339, 341, 343, 345, 347], ) retain_nodes_col = hm.Collection(model, ent.Node, [210, 277, 370]) model.elementsaddnodesfixed( elements_collection=remesh_elems_col, nodes_collection=retain_nodes_col ) model.defaultremeshelems( collection=remesh_elems_col, elem_size=3.0, elem_type=2, elem_type_2=2, comp_mode=0, size_control=1, skew_control=1, edge_mesh_type=1, min_size=0.0, max_size=0.0, max_deviation=0.0, max_angle=0.0, previous_settings=0, vertex_angle=30, )
