Model.midsurface_display_plate_sides#
Model.midsurface_display_plate_sides(plate_number, reserved1, reserved2)#
Creates two components that contain copies of the model surfaces belonging to two sides of a given plate.
Parameters:
  • plate_number (int) – Specifies the plate number for which the plate side information is to be created.
  • reserved1 (int) – Reserved for future use. Must be set to 0.
  • reserved2 (int) – Reserved for future use. Must be set to 0.
Example#
Show the plate information for the plate with plate number 127#
import hm
import hm.entities as ent
model = hm.Model()
model.midsurface_display_plate_sides(plate_number=127, reserved1=0, reserved2=0)
