Model.CE_DetailSetIntByMark#
- Model.CE_DetailSetIntByMark(collection, detail_name, integer_value, reserved, force_storage)#
Sets an integer connector detail for a collection of connectors.
- Parameters:
collection (Collection) – The collection containing the connector entities to update.
detail_name (hwString) – The name of the standard integer detail, or user-defined integer detail, to update. See
Model.CE_DetailSetInt()for valid details.integer_value (int) – The integer value to update for the detail.
reserved (unsigned int) – Reserved for future development. Must be set to 0.
force_storage (unsigned int) –
0 - Do not store user-defined detail.
1 - Store user-defined detail.
Examples#
Set the thickness (number of layers) to 3 for connectors with IDs 1, 2 and 3#import hm import hm.entities as ent model = hm.Model() model.CE_DetailSetIntByMark( collection=hm.Collection(model, ent.Connector, [1, 2, 3]), detail_name="ce_layers", integer_value=3, reserved=0, force_storage=0, )
Set a user-defined integer detail “test” to a value of 5 for connectors with IDs 2 and 3#import hm import hm.entities as ent model = hm.Model() model.CE_DetailSetIntByMark( collection=hm.Collection(model, ent.Connector, [1, 2, 3]), detail_name="test", integer_value=5, reserved=0, force_storage=1, )
