Model.CE_ConnectorSeamTrim#
- Model.CE_ConnectorSeamTrim(collection, node_collection, tolerance, snap, mode)#
Trims/splits seam connectors using nodes.
- Parameters:
collection (Collection) – The collection containing the seam connector entities to trim.
node_collection (Collection) – The collection containing the trim/split node entities.
tolerance (double) – The tolerance value used to snap the nodes to the point of seam connectors when
snap=1.snap (int) –
0 - Do not snap nodes to seam connectors.
1 - Snap nodes to seam connectors.
mode (int) –
0 - Split seam connectors.
1 - Trim seam connectors.
Example#
Split seam connector with ID 101 using node with ID 1001#import hm import hm.entities as ent model = hm.Model() model.CE_ConnectorSeamTrim( collection=hm.Collection(model, ent.Connector, [101]), node_collection=hm.Collection(model, ent.Node, [1001]), tolerance=0.5, snap=1, mode=0, )
