Model.setcurrentinclude#
- Model.setcurrentinclude(id, shortname)#
Specifies the include file into which HyperMesh should place newly created entities.
- Parameters:
id (unsigned int) – The ID of the file. If this is 0, then HyperMesh uses the shortname to find the file.
shortname (hwString) – The shortname of the file, as defined when creating the include (see
Model.createinclude()).
Note
If the ID is 0, and the shortname is empty (“”), then HyperMesh will place newly created entities in the main output file instead of an include file
Example#
Set inlcude file withid=2as current to place newly created entities#import hm import hm.entities as ent model = hm.Model() model.setcurrentinclude(id=2, shortname="")
