Model.addedgesorfaces#
Model.addedgesorfaces(entity, collection=Collection(), face_indices=hwIntListList(), edge_indices=hwIntListList(), reversenormal=0, main=1)#
Adds faces of solid elements or edges of shell elements using a specific edge/face number to a segment set or contact surface. Creates interface elements on edges of shell elements or faces of solid elements using specific edge/face numbers.
Parameters:
  • entity (Entity) – The object describing the entity.
  • collection (Collection) – The collection containing the shell/solid element entities.
  • face_indices (hwIntListList) – The face indices of solid elements.
  • edge_indices (hwIntListList) – The edge indices of shell elements.
  • reversenormal (unsigned int) –
    Determines if the secondary elements should be reversed when created. Applicable for contact. Valid options are:
    0 - Along element normal
    1 - Opposite element normal
  • main (unsigned int) –
    Determines if main or secondary interface elements are created. Applicable for contact. Valid options are:
    1 - Main
    0 - Secondary
Examples#
Add faces with IDs [ 1 , 2 ] of solid elements with IDs 10 , 11 to segment set with ID 1#
import hm
import hm.entities as ent
model = hm.Model()
input_col = hm.Collection(model, ent.Element, [10, 11])
model.addedgesorfaces(
    entity=ent.Set(model, 1),
    collection=input_col,
    face_indices=hm.hwIntListList([hm.hwIntList([1, 2]), hm.hwIntList([1, 2])]),
    reversenormal=1,
Add edges with IDs [ 1 , 2 ] of shell elements with ID 10 , 11 to segment set with ID 1#
import hm
model = hm.Model()
    edge_indices=hm.hwIntListList([hm.hwIntList([1, 2]), hm.hwIntList([1, 2])]),
    reversenormal=1,
Add edges with IDs [ 1 , 2 ] of shell elements with ID 10 , 11 to contactsurf with ID 1#
import hm
model = hm.Model()
    entity=ent.Contactsurf(model, 1),
    reversenormal=1,
Create secondary interface elements on faces with IDs [ 1 , 2 ] of solid elements with ID 10 , 11 on interface ( group ) with ID 1#
import hm
model = hm.Model()
    entity=ent.Group(model, 1),
    reversenormal=1,
    main=0
